Small engine injector?
ApplesVolvo
Post by ApplesVolvo »
Hi all
I'm interested in doing a small size engine injector: single cylinder, two stroke, 200cc.
Anyone know what injector would work and where to get one?
any leads appreciated
thank you!
FIntruder
Post by FIntruder »
What kinda wattage output does your alternator make? Probably the biggest obstacle is finding a suitable fuel pump that is not too big and draw too much.
What do you figure the horsepower of your engine is, 20 to 30hp ? This will determine how big of an injector you will need.
wildwestsydney
Post by wildwestsydney »
What kind of bike is it? I plan at some point, this spring convert my sx 125 to FI. I have allready converted my DR 350 to FI using a MSI ver 2.2 which came out pretty good. Much better than the CV carb it had.
FIntruder
Post by FIntruder »
What did you use for a fuel pump? Throttlebody? What do you estimate your horsepower output is?
the bubbler
Post by the bubbler »
Look on ebay for a fuel pump off a Peugeot Jetforce scooter. These are small fuel pumps that will be okay for a 200cc engine.
Other sources include some of the Honda scooters. They're all 'intank' pumps, so you'll either need a swirl pot or a modified fuel tank to incorporate them.
For an injector, you should be looking for injectors off of small cars. A smart car would yield a good injector, as the capacity is 700cc over three cylinder, but you may need more fuel for a two-stroke.
Andy
