Bosch LSU 4.9
1979-mini
Bosch LSU 4.9
I am trying to get it to work with the JAW controller. I don't know if the LSU 4.2 and the 4.9 can be used interchangeably or not. I assume that they should be able to be interchangeable since they are both WB sensors.
Does anyone have any experience with the LSU 4.9 with JAW or LC-1, or any other controller?
1979-mini
4.2 vs 4.9
......................................................7 057........................17 025
LSU Wire Colour ....Pin Name.......LSU 4.2 Connector.....LSU 4.9 Connector
Red..........................Ip............................6..............................1
Black........................Vs...........................1..............................6
Yellow...................Vs / Ip........................5..............................2
White........................H-..........................4..............................3
Grey.........................H+..........................3..............................4
none (green)............Rcal.........................2..............................5
Since the JAW unit is based on the LSU 4.2 sensor, the connectors on the PCB are numbered according to the third column shown above. If you have a 4.9 sensor, you need to match up wire colours (not the pin numbers).
I will update this posting when I actually wire up my 4.9 as per the above chart. I am currently wired up like a 4.2, so my connections are incorrect and showing lean all the time.
I suspect it's the same with the JAWS unit but see if you can get a hold of Toalan, he should be able to give you a more definitive answer.Unfortunately not. The LSU4.9 requires different heater drive values and different setpoints for the Sensor impedance
1979-mini
My issue is currently with establishing the calibration value of the 4.9. In JAW with a 4.2, the software says to wait for the heater value to be 14-18 when calibrating in free air.
The problem I am having with the 4.9 is that it stabilizes at a heat value of about 23-26. When I calibrate at this number, over and over again, the calibration value changes quite a bit. It should remain relatively the same ( to within 1 - 2 units).
