v2.881 release
In the current 12V configuration the tach works fine and the injector ticker sounds great.
Next step is to implement the ignition with two dual spark coils life on the test rig.
After that I have to get familiar with the tables as I use the alpha-n mode. Maybe one question for my preparation: I have found the 6x6 Alpha-N MAP table which has kPa values as result. Are those kPa values an entry of the VE table?
Thanks a lot
Norbert
Problem on single wheel
I used the original config in flash except the settings for wheeldecoding and dwell:
Single crank wheel 12-1, 0 delay teeth.
On some steady rpm points I got nearly double dwell and wrong advanced angle,thus dwell looks ok in the logs. I did a cross check with reburned 2.873 which works fine with same settings(fresh msq).
On a further try I compiled 2.881 by myself and disabled the new inter-tach time correction method by commenting out the lines 5277-5318. That worked so far.
Here two scope shots(timebase 5ms):
Working rpm/ disabled correction:
abnormal:
Bruce Bowling
- Site Admin
Re: Problem on single wheel
I want to thank you for the completeness of this post! You posted the problem and backed it up with data and the section of code that may be causing the issue - excellent! It really helps alot!MoveX wrote:Hi, tested 2.881 on bench before I wanted to load it into car.
I am sure Al is checking into this right now. Question, it seems that the issues is at the point where there is the missing tooth. If you set the advance offset to some other number do you still see it?
Same happens with 2 teeth delay:
Here the msq I used:
http://www.movex.de/down/v2.881.msq
I think I fixed your problem last Saturday, but I have spent the past week looking at and fixing other problems in the dual spark code. I tested all sorts of combinations of modes and no. of cylinders, etc, and think I have a decent working version now, so it is attached as version v2.882. No new features were added and no changes whatsoever are required for MT. Anyone who is using dual spark mode should upgrade to this version, and future units will be programmed with it.
Thanks again for the testing.
- Attachments
- Monitor_v2.882.abs.zip
- (35.09 KiB) Downloaded 79 times
- main_v2.882.zip
- (73.58 KiB) Downloaded 83 times
I have also put the code here: http://www.megamanual.com/ms2/betacode.htm. The INI and settings file are there as well, for those not upgrading from 2.881 (those upgrading from 2.881 can use the same megasquirt-II.ini and settings.ini files they were using previously).
