starting the collection
toon2
Post by toon2 »
went to a cycle salvage today.Got a FP and a coil. both are small and the pump is rated at 50 psi . I looked at the TB's they had and the injectors are small, perfect for my app.., most of them had too high a flow rate, although the cbr 600 injectors might work.
They wanted to sell the entire TB, more than what I need. SO the injector search continues.
toon2
Post by toon2 »
wouldn't let me upload pics, a message said I've reached my limit of 1mb
kholman
Site Admin
Post by kholman »
You'll have to remove attachments from your old posts to clear up space once you reach the limit. The easiest way to find and delete old attachments is to search for your own posts.
Forum Admin Team
newtyres1
Post by newtyres1 »
A good image compressor also helps like this one: http://www.xat.com/io/
or do a search on image optimizer. This will allow you post a lot more pics without exceeding the limit, and also greatly speeds up download times for those of us on dial-up!
Ian.
hybrid
Post by hybrid »
You could also sign up with a site like photobucket.
- Microsquirt Powered 347ci 66 Mustang
- MS1 V3 Powered Ford 351CI V8
- MS2 SMD Powered 307CI Holden V8
toon2
Post by toon2 »
Here's a pic. of the parts
microsquirt parts.jpg (154.33 KiB) Viewed 2168 times
coldfusiontechnology
Post by coldfusiontechnology »
what fuel pump is that ? i've been looking around a small pump but only find those car pump Bosch 350hp high flow pump ..
since you already mentioned cbr600 injectors, what is ur project bike ?
toon2
Post by toon2 »
it's a pump out of a street bike, not sure what bike. It's small, 3.5" long by 1.25" in dia.
I am Microsing a 32hp generac motor for a boat.
I heard that the injectors off a CBR might work since there are two per. cyl.. I found some injectors off a O.B. motor that have the flow I was looking for.
flyguyeddy
Post by flyguyeddy »
i have a pump just like that on my VFR and im almost willing to bet that it will NOT be an efi pressure pump. did hte bike you got it off of have carbs?
