Timing map table
bens_cab
Timing map table
Post by bens_cab »
Hi all
just starting to tune my spark map any advice my fuel table is so so but im getting some pinking noise from the engine when driving
it idles at 6deg without a problem but the car does seem to be down on power which i think is the spark table
my trigger angle is 58deg and its a turbo engine so dont want to kill it
ive seen some excel spread sheets which are an estimator where are these
VW Mk1 Golf Gti Cab 20v turbo msns extra 029q2 v3
boost junkie
Post by boost junkie »
post your MSQ.
-shawn
msns-e controled turbo neon
sample msq's!
bens_cab
msq
Post by bens_cab »
here it is
bens_cab
help me
Post by bens_cab »
anyone???
Fastest95PGT
Post by Fastest95PGT »
I have never put an NA motor past the upper 40's for timing and that's at high rpm midrange map values.
I don't know your motor, but I would suggest that if it's actually 58* then you probably want to retard it considerably for peak power as well as getting rid of the pinging.
1995 Ford Probe GT ~ Megasquirted & Boosted
2003 GSX1300R (Hayabusa)
bens_cab
lump
Post by bens_cab »
the engine is from an AUDI A3 it a 20v turbo lump fuel injected 150bhp from standard
Fastest95PGT
Where did you get 58* from? Maybe you should post your spark map for us to get a better look?
My point before was that 58* is very high for any NA motor let alone a boosted one.
bens_cab
hmm
Post by bens_cab »
my trigger angle is 58degs using the vr as tach input
Fastest95PGT
Sorry, I mis-read the 58* as highest spark table value, not your trigger angle.
That map looks alright for a normally boosted motor.
Big Creek
Post by Big Creek »
At what RPM and load do you seem to getting the greatest amount of ping? Does it seem to be under light loads during cruise or heavy high rpm loads?
Todd
1979 Porsche 924, 2.0L 4cyl, 1.6L Whipple SuperCharger, MS-I V2.2, MJLJ, MSnS 029q2
