Inj Bank 1 & 2 inconsistency help please...
hobieboy
Post by hobieboy »
Hi,
A bit of background first: MS-I v3 board, 29q2 code. 6 cylinders and injector set to alternate, 2 squirts. Injectors were new & flow matched. Common fuel rail across the 2 banks.
Have been trying to get the car to idle but she starts very well (usually ~2 cranks), stays running for ~5 seconds then die. When running, my MAP shows ~70kpa which seems high.
Now the question/help needed - I finally decided to pull the plugs and take a look. The left bank looks to be perfect - a bit black in the center and dry. The right bank - the entire injector is black and wet.
So, this lets me to think of dead injector driver for 1 side? But... car will NOT start if only 3 cylinders are running. I'll do the LED test later today.
BUT... can it somehow be that the injectors on the left bank is not fully opened so the entire side getting inconsistent fueling? How could I verify this?
thanks.
jsmcortina
Post by jsmcortina »
Check the injector driver components and flyback on the circuit board. If one channel has different flyback then I would expect the injectors to behave differently.
If these are hi-Z then the megamanual says that you can connect all six to one channel (for testing.)
hobieboy
Post by hobieboy »
James,
Sorry for being slow :oops:
How could I check flyback? What kind of voltage/pulse should I expect & where to tap into?
thanks.
jsmcortina
Do a visual inspection first, make sure the big diodes are in the correct direction and are soldered well.
hobieboy
Post by hobieboy »
ok - did the visual inspection and everything looks good.
I also noticed that the log also shows flyback from the portA status occassionally. What does that mean? I have included one of the logs as reference.
Any suggestion where to look & what to do next?
thanks.
hobieboy
Post by hobieboy »
I scoped the flyback circuit during cranking and they both appear to be working correclty and returned the same waveform. Voltage was clamped ~36V.
Just to prove that its not the rest of the fuel delivery components, would it cause any problem if I swap the power connector between the 2 banks of injectors so that bank 1 becomes bank 2 & vice versa?
thanks...
chrispel
Post by chrispel »
Check your coils maybe one is bad causing them not to fire right.
MS2 V3.0
92 Saturn SC2 Vortech V1 A Trim
98 Saturn SC2 DP Nitrous
tbitz
Post by tbitz »
Swap the injector driver from left to right bank and see if the problem follows the change. Do this at your injector wire harness not in the MS unit.
This will help narrow problem to MS <--> injectors, ignition.
