Here's my settings:
The coil is a standard MSD Blaster TCI coil, I also tried my stock coil with no luck. I've tested the board on the stimulator and it all checks out. I'm getting continuity from the processor to the VB921 and from the VB921 to the coil. VB921 is switching between high resistance and low resistance so that shows me it's sending a spark signal but for some reason the coil is not sending a spark. The coil is powered off of the fuel pump relay and I have verified it is getting power. The distributor cap has continuity. The ignition wires have continuity. I've tried holding the main coil wire against the head and there are no sparks. I've tried using an LED test light but I don't get any light on it when I hook it up to the VB921. I've heard that the signal is too fast to see on an LED light though. Literally i've tried everything and i've been troubleshooting this for 6 months. Nobody seems to know what is wrong or how to help me.
Can someone suggest a better ignition option? Should I do EDIS or MSD? I just want it to run. I don't care anymore if I get to control spark thru Megasquirt. My car has been down for almost a year and I just want to drive.
