weird problem with air fuel gauge
now when im in mega tune on the screen with all the guages my AF gauge is stuck at 11.9. but when i go in to my AF table that large gauge is stuck there to but the spot below the map is reading right i think cuz it moves around where i want it to go for the AFR.
anyone have any ideas whats wrong?
When you set up MegaTune, did you use mtCfg.exe to select the LC-1? (http://www.megamanual.com/megatune.htm#installprocess)
Then when in MegaTune, did you calibrate the AFR table to the LC-1? (http://www.megamanual.com/megatune.htm#oa)
Those are the two most likely problems (assuming you activated the corrct INI file for your code).
