Does Alpha/N require the use of Individual Throttle Bodies?
Thanks!
jakobsladderz
The reasons for going with alpha-n are
1) very lumpy cam (with any throttle body style) where idle vac is low and/or MAP reading jump around like crazy.
2) you are using ITB's and don't have a place to hook up the MAP sensor to, whether running a lumpy cam or not.
Alpha-n is not really suited to street cars, there are too many things that can change and mess up the mixture.. on a racetrack, it's ok but you will probably have to tweak fuel settings often..
