Stock EDIS
To4e turbo
MSII v3.0, v2.35 code, MT 2.25
LC-1 wideband
#30 high impedence injectors
Ive been playing with truck getting it tuned and everything. From a cold start the truck idles and runs perfect. Ive had it up to 4000rpm and its runs pretty good so far. Warm starts are a no go, ive played with the afterstart but cant seem to get it to catch. It will start and die with each key turn. Today its 92 degrees out with a humidity of 50%. My truck has been sitting in the garage so the coolent temp was 91 and and the MAT was in the 90's also. The truck started and died as usual. Normally I just feather the gas a bit just after cranking and it catches fine and stays running perfect. Well today I feathered the gas it started but runs horrible, its chugging and puffing white smoke like crazy. As soon as I take my foot off the gas it dies too. I noticed my PW's while cranking where 13-20ms. Is this typical for a engine to run like this with high temps and humidity. Just sitting in the truck i was sweating like crazy
