MS2 rpm output
MS2 rpm output
First, the motor is going to be a nissan rb25det straight 6. the chassis is a 89 nissan 240sx coupe. basically my first question is if i were to use the ford edis system, would the ms2 be able to send a modified tach signal to the stock 240sx cluster since the engine is a 6 cyl and the cluster is made for a 4 cyl?
Also, i know that the ms2 is open source and highly customizable, is there any way to control boost using a cheap solenoid?
Another thing i wanted to find out about was how do most of you handle the ignition side of things regarding knock/detonation. is there a 3rd party knock sensor kinda like a wideband 02 sensor, or do you do things using a stock knock sensor? basically i would want the ms2 to pull back timing if experiencing knock.
Right now this is all i can thing of as its 3:10 am and im about researched out for the night. i appreciate all replys and hopefully i won't get flamed too bad, i know im a newbie and all but man is it hard to find a straight answer. Thanks in advance
jsmcortina
- MegaSquirt Guru
jsmcortina
- MegaSquirt Guru
http://www.megasquirt.info/ms2
and then choose Embedded code on the left hand pane. From there you can download the entire source code and there are links to compilers and development environments.
