surging
surging
I'll try to keep this short. I can get my engine to idle around 1000rpm and for no reason it will drop in rpm and quickly recovers and then idles along for 10-15 sec or so and then drops in rpm again recovers.......
ignition timing is about 35 degrees, pulling high 30's low 40's kPa at "idle"
I have tried many different ve tables by generating new tables, I have tried making a flat spot around the "idle" on the ve table, I have tried changing the req fuel. The most I have been able to do is changing the rpm but it still surges.
Any ideas or pointers would be great!!!!
This likely isn't a issue with the VE table, it's much more likely to be something like accel enrichment coming on inadvertently (which does exactly what you describe).
A giveaway is that the LED furthest from the DB9 on MegaSquirt flashes quickly when the engine speed drops (if it hasn't been reassigned for some other use).
If you could post a datalog, that would be very helpful for confirming or denying this, as well as for looking for other causes.
