I reloaded the 2.1 firmware as I had no luck getting it to work with 2.34 firmware. As I mentioned before, I had the problem that I did not have ignition output when the engine was cranking.
With 2.1 firmware the car started right away with the settings that I already posted before. That ist the falling edge of the Hall signal set to 16° BTDC set with the dizzy and the other settings being:
Ignition Input Capture: rising edge
Cranking Trigger: trigger rise
Coil Charging Scheme: normal
Spark output: going low
After that I reflashed the new 2.35 firmware and it works with it, too.
What I do not like at the moment is that at idle the ignition timing is moving around as much as 400µs which is approx. 2° crank angle. I do not know how much it is when the engine is running at higher rpm, but in transient operation it will probably be a lot more. This is the fact with all algorithms that I tried. It's clear that when having the hardware falling edge set to 16° and wanting the ignition to occur at 18° BTDC for example, the engine has to rotate 178° degree between the falling edge of the Hall sensor and the ignition event.
The problem is that I need the falling edge set to 16° for starting/cranking. If I set the falling edge to 40° BTDC and change the settings in MS-II accordingly, the timing gets much more precise and the timing is rock steady at idle. Unfortunately I cannot use the falling edge for cranking then. A calculated cranking trigger has to be used, which makes the car much more difficult to start.
What I tried next is to turn the dizzy, so that the rising edge was set at 16° and the falling edge at 71° BTDC. I tried to use the falling edge for ignition input capture (which is set to rising edge as it is inverted) and used the rising edge for the cranking trigger, with the settings being:
Cranking Trigger: trigger fall
With these settings I do not get any signal on the ignition output when cranking!
What might cause this problem??? All I am changing is the cranking trigger setting from "trigger rise" to "trigger fall" and there is no output.
Please give me some advice, cause otherwise either the timing at normal operation is not very accurate or the car is very hard to start depending on what is "optimized".
Cheers,
Tadek
