MAP Question?
mopower98rt
MAP Question?
Any help would be appreciated.
Thanks in advance.
jakobsladderz
If the engine was running fine before and isn't now, increase the injector calibration constant until it runs fine again..
mopower98rt
jakobsladderz
I guess the possibilities are: wiring - injectors open fulltime and extra air through vac port is just enough to idle, check wiring, etc..; injector cal too large and causing major flooding, check pulsewidths are reasonable and adjust cal one way or the other; other issue???
are all the readings ok (MAP, engine revs, temps, etc..).
mopower98rt
I will look at the injector calibration tonight.
The MAP of course reads wrong since it has no vacuum but all of the other readings are dead on.
