Voltage logging?
fordfanboi
Voltage logging?
Post by fordfanboi »
Is there any sort of voltage logging I can view in the data logs for the MS II? I'd like to record what my voltage readings are.
Thanks!
bleoh
Post by bleoh »
IIRC that is one of the standard readings that is logged.
MS2 v3.0 MT2.25 controlling 6 high z injectors and ignition
Bleoh, fordfanboi,
I don't think battery voltage is in the standard MS-II logs in order to manitain compaitibility with older logs. It is easily added though.
Add the line:
Code: Select all
entry = batteryVoltage,  "VBatt",       float,  "%.3f"
to the [Datalog] section of the megasquirt-II.ini file (near the end) and you will be logging battery voltage.
I use MegaLogViewer, so I can just select VBatt once I load the datalog to see the voltages.
Note that 'batteryVoltage' also needs to be in the 'Output Channels' in the INI file, but it should be there by default in MS-II in a line like:
Code: Select all
batteryVoltage = { batADC / 255.0 * 30.0 } ; Current MS power supply voltage.
More on voltage logging: http://www.msefi.com/viewtopic.php?p=94 ... batt#94115
fordfanboi
GREAT! Thanks much!
fordfanboi
I didn't see exactly what you typed in my .ini. Here's what I have - is it correct?
batteryVoltage = scalar, S16, 26, "v", 0.100, 0.0
Thanks!
fordfanboi,
Yes, that will work! You still need to add:
Code: Select all
to the datalog section of the INI, of course.
fordfanboi
Yep - got'r done! :D
Thanks much!
