supercharged w/ms, need some help
r there any other areas that i should pay attention to with a sc as opposed to a turbocharger?
Fastest95PGT
As you said, you can't use TPS because boost is based on RPM in a SC setup.
I could see if the thread starter was going to have a WBO2 all the time to just use the target AFR table and leave it closed loop at all times, but since they're using an NBO2, what would people suggest?
2003 GSX1300R (Hayabusa)
You want to be richening up after 80-90kpa.
Thing with a s/c is you should get instant boost at any rpm when you floor it ( I see 12psi at 2000rpm), so you need to tune the upper parts of the VE table accordingly.
The general rule for boost, turbo or super, is that you must retard timing and go rich, like 11-12.5:1. I noticed people with miatea do different things with the two, but that is likely due to higher supercharger intake temps. Speaking of wich, make sure your IAT is after the blower.
