Page 1 of 2
DIY Tuning - how to begin?
Posted: Fri Sep 10, 2004 7:59 pm
by TheDarkMajestic
Where do i start about this black art?
DIY Tuning
Posted: Fri Sep 10, 2004 8:33 pm
by TT350chevelle
Try here:
http://www.megasquirt.info/manual/mtabcon.htm
Look under the "Tuning Your MegaSquirt" section.
Brad J.
DIY Tuning
Posted: Sat Sep 11, 2004 4:01 am
by whittlebeast
Getting the nerve to get started is the most dificult. Once you do and get the motor started, the next part is easy. Get a friend to do the tuning first in the driveway and later in the street. Be VERY gental on the throttle. Do lots of data loging and post anything you don't understand. Include the logs and the msq file. Noise in signals (tps, map, rpm and temp) must be delt with before any real tuning can be done. If you can get a MSQ file from someone with a similar car would help (displacement, turbo or not, and the same number of cylinders, about the same size injectors are the most important things) Stay with the basic s19 files and GM sensors if at all possible at first for support issues.
Hope this helps
AW
DIY Tuning
Posted: Sat Sep 11, 2004 3:13 pm
Yeah, the only thing I would add is that tuning is a skill.
If you are new to tuning, it will seem difficult at first and your engine probably won't run quite the way you want it to. As you work at it, though, two things will happen:
- you'll narrow in on the optimum settings for your engine,
- you'll learn the skill of manipulating the various parameters, to get them to work together to produce performance, economy, driveability, etc.
So read all you can, then give it a try. And don't give up if you don't get it running perfectly in a half an hour. Like any skill, it takes practice. Keep working at it, and you'll eventually get the skill perfected, and not only will you be thrilled with how your engine runs, but you'll be happy to have a new (and quite rare) skill!
DIY Tuning
Posted: Sat Sep 11, 2004 3:56 pm
by efahl
Lance,
Your forgot the third thing:
- You become obsessed with tuning, and diagnose every little quirk
in driveability in every car you ride in, even the ones you can't
change ("I wonder why they didn't richen the cold AE on this thing
a bit to get rid of that stumble?").
Eric
Eric Fahlgren
http://www.not2fast.com/
DIY Tuning
Posted: Sat Sep 11, 2004 4:09 pm
Yeah definitely, Eric!!
And you may find yourself changing things (manifolds, cams, etc.) on your car just SO you can do some tuning.
Ahh, life is rich!
DIY Tuning
Posted: Mon Sep 13, 2004 4:08 pm
by Enthalpy
lance wrote:Yeah definitely, Eric!!
Ahh, life is rich!
LOL...SO FREAKING TRUE!! I found myself changing my base pressure under the excuse of "better atomization" (which turned out to be true). I really did it so I could retune everything.
Majestic - I think you have an MR2 because there's someone with your name on our board. I'm "flyboy" on the MR2 board (Enthalpy was taken).
Welcome to the aftermarket EMS world! You will love it!
I have tuned a bit now. If you have MR2-specific questions, feel free to drop me a line!
damon.becker@comcast.net.
DIY Tuning
Posted: Tue Sep 14, 2004 7:42 am
by Enthalpy
Actually, I transitioned away from MS when I realized knock would be a serious problem on my setup. *hangs head in shame* I did, however build one awhile ago.
I might go back if MSII supports knock sensing. If it supports ion sensing, then I'll DEFINITELY go back!
Re: DIY Tuning
Posted: Fri Oct 14, 2005 8:14 am
by T3Bunny
Enthalpy wrote:I might go back if MSII supports knock sensing. If it supports ion sensing, then I'll DEFINITELY go back!
MS 1 supports knock sensing! Look at this:
http://megasquirt.sourceforge.net/extra/knock.html
Sure, its "expirimental" (but then so is the whole MS project...) but there are a lot of people out there with this working. And you can get a knock sensor kit out of the products and services section.
Posted: Fri Oct 14, 2005 11:28 am
by Enthalpy
That's very interesting! I didn't know this existed.
