drz400 one cylinder engine rx8 coil problem.
Tibor
Post by Tibor »
Hy All . I am trying to retrofit the drz400 one cylinder engine with the microsuirt modul Everthing works now except the ignition part.Iam using rx8 ignition coilThis has 3pin connector.I am sure this is a logic level coil >so should be fine fine with the microsuirt.My wheel pattern is 6-1 on the crank. The setting is wasted spark .The 5v square wave is coming out from the modul .I checked with scope.The rx8 coil brand new .I checked the spec. Iam using fiat lead what is 10k ohm .Could this a problem (the lead? So not works. Any help appreciated. Cheers
Tibor
Re: drz400 one cylinder engine rx8 coil problem.
Post by Tibor »
Its works now.The rx8 coils fine with microsquirts module. The spark little week but my lead is 10k and the original mazda 2-3k i think SO ill change.The real pinouts are different what i found everywhere :yeah!:
