no injector pw while cranking!!
My problem is that whenever i crank the bike the injector pw is 0 and when i released the starter button it goes back to a normal pw. SO... there is no gas injected while i crank so no wonders the bike doesnt start...
i have a microsquirtV3 controller with code 3.830 and im doing my setup in tunerstudio MS. I only want to use fuel injection, i dont want to control ignition.
i have good readings on Rpm , IAT ,ECT, MAP ... (rpm is trigger off a negative coil via opto)
I have check the voltage while cranking on the microsquirt fuse and injector fuses and its about 9-10v...
i have done the injector test mode with great success...
i have reloaded firmware and build a new msq file...
im running 4 high impedance injector but i cant find the setting in tunerstudio to change the power unless i pay for the pro version of the software...
One thing i noticed in tunerstudio is that whenever i crank the bike , the crank state at the bottom screen doesnt light up but my rpm is around 130-150 rpm while cranking!!
heres my msq and datalog
hope somebody can help!!!
Re: no injector pw while cranking!!
The log you posted is showing a 4.5 ms pulse width while the starter is turning. Make sure the injectors and ECU are powered off a wire that still has 12 volts when the starter button is pushed.feak1 wrote:hi there
TunerStudio Lite does not lock you out of any ECU settings. It's just that MicroSquirts do not do PWM current limiting, so you cannot "change the power".im running 4 high impedance injector but i cant find the setting in tunerstudio to change the power unless i pay for the pro version of the software...
