Trigger sensor wiring on Yamaha RZ350/Banshee
Posted: Wed Oct 22, 2014 9:24 am
by sweet_baby_james
I am about to start installation of an EFI setup onto my 85 RZ350. I am pretty comfortable with most of the steps (I am just using it for fuel control, not ignition at this point). However, I am getting stuck on how to wire up the pickup from the stock ignition system to the Microsquirt. I am using the stock CDI ignition that has two lobes on the flywheel and one pickup sensor. I an article http://www.smcomp.com/~smurph/RZ-EFI/install.html that uses an HEI module to make the stock sensor work, but this was not with the Microsquirt ECU, so im not sure if this is required.
If anyone has done this with their RZ350 or Banshee I would really appreciate some help.
