software
doodyrwh
software
Post by doodyrwh »
i just bought a 63 Biscayne has a ls 5.3 with twin turbos and runs on e85 fuel and it ran fine the first 4 times driven and on the test drive with guy I bought it from it starts and runs but the air fuel mixture guage is floppin all over the board when it is running correctly the guage runs between 11 -12 runs bad flops between 14-16 or all over I don't know anything about the v 3 microsquirt what software do I need to be able to plug in and watch it to see if its a fuel or computer issue and where can I purchase ???????? thank you in advance
Re: software
Hi,
If you just want to see the readings, TunerStudio Lite here will do, later if you want more bells and whistles, you can upgrade for $50 to the "pro" version, or if you want to log stuff and view what's happening later there is MegaLogViewer from the same vendor. There is also an Android option too.
