Erratic rev counter
Posted: Thu Apr 24, 2014 11:20 am
Running a V3 microsquirt system on my V6 Duratec, everything is fine and runs very well however I have only one nagging issue and that is the rev counter, I am using the original Ford Mondeo V6 rev counter and all was well at first except when any electrical functions was used the rev counter would give a quick dip to 0 then back up other than that it would work fine, however the more I use the car the fault is getting worse, sometimes it just dies for no reason then will come back on again but very erratic in nature, I have double checked every thing I can think of, even tried another rev counter just to make sure. I am using the Ford EDIS unit hooked up to the Microsquirt module, I have also tried to get my rev counter working from the EDIS unit with no luck, should I have something else on the rev counter wire from pin 35? whatever it is it does not effect the running of the engine
Alan
Alan
