3.830 code bug
3.830 code bug
I found a bug in the serial comms for 3.8x code that has been there for some time. But it only affects the comms in rare circumstances when the engine is NOT running. I only saw it in alphaN mode. The fix was very minor and it is attached; no new ini file is needed. Nor should you have any problems with msqs, just save the latest one and restore it after the bootload.
Monitor_v3.830a.abs.zip
(50.26 KiB) Downloaded 65 times
Re: 3.830 code bug
Al,
Indrek86 & I are showing incorrect engine speed in TunerStudio with this firmware using a single missing toothed cam wheel & one sensor. Can you look into it please?
3.76 appears to be OK, but 3.83 shows cam speed not engine speed.
Thanks,
