Not firing injectors while cranking
Maick1
Post by Maick1 »
Injector test mode works Ok and injector are firing as supposed. I´m getting steady 230 rmp while cranking but injectors aren´t firing at all. I have spark on both plugs. Maybe setup problem ?
2013-05-07_21.32.57.msq
(30.2 KiB) Downloaded 313 times
Maick1
Re: Not firing injectors while cranking
Post by Maick1 »
fuelpump output stays off after prime pulse. No signal while cranking.
Maick1
Post by Maick1 »
Problem solved. New firmware version v3.78 did the trick... who knows :D
