3.830 code release
3.830 code release
- Attachments
- megasquirt-II_v3830.ini
- (159.73 KiB) Downloaded 87 times
- Monitor_v3.830.abs.zip
- (49.71 KiB) Downloaded 94 times
fabio.silva
Re: 3.830 code release
I updated the Microsquirt V3 to 3.830 code release and now the fuel pump "start and stop" continuously. Whats happen?
Thanks!
You probably need to set the ECU type. For more info, see the red text here: http://www.useasydocs.com/details/usv3code.htm
fabio.silva
That's right.
Thank you!
It seems to work, although I have not put the engine in yet to check.
Is it possible that the s19 file I downloaded is an older version? I also have no launch control or flat shift in tunerstudio now? Were these removed?
However, if you want launch control and flat shift you have to use extra code and the extra ini file that goes with it. TS only provides the input and output interface for what is in the code that you load in the ECU. If you are going to use extra code you need to read and follow that documentation and ask questions on that forum.
