few questions from a newbe
Posted: Sat Feb 18, 2012 7:55 pm
by odum13
A few questions
Working with a 2007 yamaha r6r motorcycle
What or how do you find out the setting for manifold displacement
Ignition trigger settings any help there also
Any links for help on motorcycle motors
Really feeling stupid right now
Thanks in advance
Re: few questions from a newbe
Posted: Sun Feb 19, 2012 8:38 pm
by dontz125
Welcome to the madness!
I believe the later R6 use a 12-1 trigger wheel ; not sure what the tooth #1 angle is.
What do you mean by manifold displacement?
Posted: Mon Feb 20, 2012 9:01 am
odum,
Manifold Displacement is the actual physical volume if the interior of the intake manifold. It is only used if you are using the model based algorithm (and we need to modify the INI so that it only shows up for users in that case). So if you are not using the model based algorithm (instead you are using speed density with a MAP, alpha-N with a TPS, or you are using a MAF directly) then you can ignore this parameter.
If you are using the model based algorithm, you can either measure or estimate the manifold volume. A typical V8 single plane manifold is around 2400cc. A 4 cylinder might be around 1200cc with a 6 cylinder around 1800cc. Of course, if your engine is smaller than 'normal', the value is likely smaller than that.
There is more here:
http://www.megamanual.com/mt37.htm#sg
Posted: Sun Mar 18, 2012 7:41 am
by odum13
Thanks Lance
How do I increase the cell size to larger than 12?
Posted: Mon Mar 19, 2012 4:05 pm
You can't change cell size for ve. You would have to go to msextra code for that.
