2nd trigger/cam input via Hallsensor on Microsquirt module?
pigga
Post by pigga »
Hi.
Short question:
How should I hook up a 2nd triger signal coming from a hall sensor to the µsquirt module?
The sensor is a 12V Bosch open collector type, i.e. it will switch an applied voltage to GND or provide a 12V/0V square signal if a pullup resistor is applied.
At MS2 the manual requires a tiny optoisolator-circuit wich goes directly to a processor pin.
What is best way to do this at Microsquirt module?
Thanks a lot in advance,
Thomas
Re: 2nd trigger/cam input via Hallsensor on Microsquirt modu
Just wire it to the second VR conditioner; this will be able to take a 0-12 volt square wave fine while buffering the voltage from the processor.
pigga
Post by pigga »
Hi Matt.
As mentioned at another place already: That's the info I needed. Thanks a lot!
Thomas
