Tried Everything I can think of... MS wont communicate
aarondost08
I can hear the relay click on and off. I took out the AMPSEAL harness and volt tested in and im getting 12.5 volts at the harness so I know Its gettin good power and ground.
I am using a comport with NO usb adapter, The port checker found ports 1 and 3 but had no connection made.
I am getting absolutley no response out of microsquirt and im at a dead end.
Anyone have ideas on what to try next? would there be a way to test and see if my unit is defective?
Re: Tried Everything I can think of... MS wont communicate
revolutionary
running directly on a serial connector or through a usb adaptor we've tried sending the msq file to the ecu but it shows low battery and doesn't want to flash. If we rebootload it shows batt voltage ok but wont read sensors correctly, tps etc. Then if we turn off MS the next time we turn on it shows low batt.
Frustrating and time limited.
