Actually running with a MS on a 1272vw polo G40, I'm trying to set up the trigger offset with the trigger wizard tool.
The problem is that the offset is perfect at low rpm, and when I want to go higher (>2500rpm), the offset is not equal to the timing ligth reading. Difference is nearly 30°. EGO disabled, no correction.
I don't understand wich parameter is wrong on my MSQ...
The RPM input for my MS is the original four windows vw hall effect (modded with 1kohm resistor).
Anybody have an idea about the problem ?
My MSQ as attached file...
Thanks for help !
