compare mega and microsquirt by the same .msq file
as title,i use the same .msq file and the same engine(cefiro vq2.0) on megasquirt and microsquirt,just change option for megasquirt or microsquirt.
than i found that mega shows rpm value is about 800 and microsquirt shows rpm value is about 4000.
does my microsquirt have some problems?
and i use microsquirt on my 50cc, 4-stoke, one injector engine,i have changed my option for skip(36),singale crank wheel.and i can't see the rpm.
if i want to see the rpm,i must setting on no dual spark option.and the rpm is twice than real rpm.and when i tune my engine i found my engine rpm
is shut down when arrive about 5000rpm,so i am confused by these problems.
because i found microsquirt vr input is not well connected and now i connect my vr sensor output to microsquirt hall channel to see the rpm,or my rpm is flounce even not shown.
best regard
- Attachments
- 09MAY11_A.msq
- 50cc engine
- (25.35 KiB) Downloaded 92 times
- HCCI_part_two.msq
- cefiro engine
- (25.02 KiB) Downloaded 73 times
