Megatune 2.25p3 strange behaviour
just received my brand new MicroSquirt and hooked it up to my laptop.
After sorting out some ini-errors (i.e. ignoring them) I could open MegaTune and the data from the MS could be read.
I could open for example the AlphaN-MAP table and edit it.
After some time most of the menus are greyed out and I cannot chose them anymore.
When I save the msq and re-open the file it works (at least for some minutes)
MegaTunix didn't like the Microsquirt at all. It couldn't determine the processor/code type and "froze".
Any ideas what could be the cause of that ?
Then I tried to get the "right" ini file for the delivery version of the MS (MS II 2.886), which was successful, but where can I find example msq's like they exist for msns-extra codes of MS I ?
(Above effect still there with the "right" ini-file)
BTW: I had a MS I V2.2 before and that unit works fine in the bike and with the stim - at least with MT 2.25 which I used then. Also this confirms that my PC hardware is somewhat ok.
Martin Kieltsch
MS I, V2.2
MS II, 2.886, MicroSquirt (currently installed and running)
Re: Megatune 2.25p3 strange behaviour
Only thing I did was change the settings for the baud rate.
Martin Kieltsch
MS I, V2.2
