Another Trigger Offset Question
obxer
Currently my trigger offset is set at negative 1 in MT. I've read that the trigger offset should be a *large* negative number. When I try changing it to -359, I only get occasional coil firing when cranking - something is definitely not working right - though my cranking RPM shows a good 350 RPM in MT. If I change the offset back to -1.00 it fires right up. Do I need to figure out what is going on here and make adjustments so I have a *large* negative number for offset instead of -1.00? Am I going to have trouble later at higher RPM? I've attached my current msq- maybe there's something I'm missing and I'm compensating with the -1.00 offset?
TIA for responses.
- Attachments
- 700-8-27 final.msq
- (25.12 KiB) Downloaded 35 times
obxer
Re: Another Trigger Offset Question
I need to start working on my spark map but I'd really like to get the offset question figured out first.
http://www.microsquirt.info/2cylCOP.gif
obxer
