Required Fuel Dialog Box .. possible bug?
Posted: Tue Apr 01, 2008 9:40 am
I don't know if this is something I am doing wrong, but I have noticed if I open Fuel set Up>Injection Control -Page 1 and click on the "Required Fuel..." button to open up the "Required Fuel Calculator" dialog box and I decide to click "Cancel" it crashes MegaTune 2.25p1.
Is this normal?
Posted: Tue Apr 01, 2008 11:33 am
by Matt Cramer
It's definitely not normal... unfortunately, I don't know what is causing it. All I know is it shouldn't happen.
Posted: Tue Apr 01, 2008 12:02 pm
I just thought that the dialog box opens and removes the info, must have default settings for the dialog box, and when you cancel they are still =0 and it can't accept these values.
and then you get the error messages and bingo..
Posted: Wed Apr 02, 2008 6:20 am
by Matt Cramer
You do get error messages if you have a "blank MSQ" full of zeros. But that shouldn't crash MegaTune.
Re:
Posted: Mon Apr 21, 2008 4:58 pm
by efahl
24c wrote:I just thought that the dialog box opens and removes the info, must have default settings for the dialog box, and when you cancel they are still =0 and it can't accept these values.
Ok, I'm not sure I'm following you here. What is the state of your configuration when you open the require fuel dialog? Do you have the number of cylinders and number of squirts set?
Eric
Re: Required Fuel Dialog Box .. possible bug?
Posted: Sat May 03, 2008 12:58 pm
Sorry about the delay in responding, what happens is I have all the values set, but I decide to click the req fuel calculator button, it auto zeros the cubic capacity etc, but if I decide to cancel...it does not like the zero engine capacity, comes up with an error dialog and crashes the software.
