im a noob at this and need help
red93mr2
Post by red93mr2 »
i have the microsquirt ecu and a 2.5 bar gm map sensor i was wondering what else i need to make this work or if i can use my stock sensors and relays and just wire it up? any suggestions will help greatly thank you
That would depend on what your stock sensors are. Is this in fact a 1993 MR2 (if so, what engine?) or something else?
red93mr2
Re: im a noob at this and need help
Post by red93mr2 »
i also have a 1987 toyota mr2 4age which i want to turbo becasue i everything except engine management to do it because i dont want to run on the stock ecu so i have all stock sensors i know ill need a map sensor but i dont know what else i will need or if i can just wire it up and tune it with the stock sensors. any help help will be greatly appreciated
thanks
justin
This one's pretty straightforward, although to use the VAST ignition you'll need two pull-up resistors. Solder a 1K resistor between the 12 volt wire and the ignition input, and another between the 5 volt wire and ignition output. You'll also be better off replacing the barn door AFM with a section of straight pipe and a IAT sensor.
