megasquirt!---------- some questions
02 Vortech
i was wondering if i could run an MS2 piggy back my stock 4.3L computer to control the fuel/spark and boost maps, as well as bigger injectors- and let the stock computer run the the transmission functions
FoundSoul
Note that's just a quick rundown, and not necessarily in the order you might go about things, and I can't promise you I thought of every bump in your road. It might be best to start with fuel control, go ahead and do all of the above EXCEPT the spark output change (you do need the spark input shared with the MS at this point). This way you've got full fuel control, but the stock ECU is still controlling ignition. You can dial in your fuel map and get the car running good, and then move spark over as well with this transition being much smaller than taking it all on at once. Not to mention you'll know the MS ECU and the tuning software MUCH better.
02 Vortech
also does the MS batch fire or can it do sequential firing as well?
