Ignition Map Configurator
JakobM
Post by JakobM »
Hi
The Ignition Map Configurator has allready been tested at a Danish tuning forum, however it would be much appriciated to have some of your oppinions as well.
I am looking for comparison with existing well working maps or just reviews from start-up experience with the Configurator. Please note that it is not made to give an "over-retarded-100%-knock-safe" spark table, but rather an average tuned startup-map.
When giving feedback please list your engine setups as chosen in the configurator.
Thank you in advance :D
/Jakob
***OBS*** New betaversion 1.06 uploaded
bens_cab
cool
Post by bens_cab »
hi mate
ive got a 20 vavle turbo engine from an audi a3 i need to make a spark map but cannot find all the info needed plus i have 5 valves per cylinder your configurator only goes to 3
VW Mk1 Golf Gti Cab 20v turbo msns extra 029q2 v3
JakobM
Post by JakobM »
All of the info needed should be there i.e. when choosing valves one of the options is >3 valves per cyllinder. That is your engine.
Which other info do you need?
bens_cab
ah i see
Post by bens_cab »
compression?
bore size?
max advance
im new to tuning the timing so its very confusing
JakobM
Post by JakobM »
All of them are there plus more under step 2
bens_cab
ok
Post by bens_cab »
what about the advance bar part only used to kpa
i have an idle of 10deg
not sure of my max advance my trigger angle is 58deg so should that be my max advance??
bens_cab
hmm
Post by bens_cab »
i know the following
compresion is 9.5:1
bore size 81mm
stroke 81mm
cc 1781
JakobM
Post by JakobM »
You dont have to worry about your max advance or idle advance the configurator will tell you. Look at the input range cells which are to copied/transfered into the dropdown list boxes. You only need to tell which engine setup you have in step no. 2. Hereafter all numbers are given to you.
You can set whatever bar/kpa margins you want at the spark table. It will do the right calculation automatically based on your engine setup. Just swift the bar dropdown value and the Kpa value will follow (Bar*100) + 100 = Kpa) and you will se the change in retard/advance.
bens_cab
cheers
Post by bens_cab »
think i have it now ill compare my existing map to the one the configurator gives me
JakobM
Re: hmm
Post by JakobM »
bens_cab wrote:i know the following
compresion is 9.5:1
bore size 81mm
stroke 81mm
cc 1781
Look at step 2 here:
You will need to fill in all of them and hereafter transfer the input to the dropdown list in step 3. Hereafter you have your ignition map. Some may want to go 1 bar/200 kpa in pressure others 1.5 bar/250 kpa and with different bar/kpa margins. You can change this as much as you want and automatically have ignition map for these pressure margins vs. rpm. in step 4
