hallsender og pullup resistance
what i don't know, even though i've read the manual, is WHERE this resistor goes..
Resistor i'm using is a 1.0k ohm 1/4w
tried to soldier one on the signal cable from the hallsender, and that didn't give me any luck, unfortunatly!
I've done all the other mods that the manual sais, by jumping to JS10 etc (can't remember that now because my unit is at home and i'm at work)
Everything looks good when i power up the MS in my car, but no signal from hallsender, ergo no spark..
Help is much appreciated!
System: MS2 v3
Regards
Dan
hopefully i've done it right?
heres how it is now:
Signal from hall to pin #36 on the DB37cable (routed around the relayboard)
Ground to tps ground
12v from injector positive
And since i don't have any signal, i don't have any spark!
anyhow.. does MT give you a warning message when you burn anything to the processor? because mine don't, so i don't know if it has been written or not
You should get a nice square wave now. It's also recommended to use the 5 V supply from the MS2 (TPS Vref) to power the hall sender because it's a filtered, regulated voltage, unlike taking 12 V directly from the injectors. You'll get a cleaner signal.
Eduardo
Jumpered R43
Jumpered D1 and D2
Jumpered IGBTout to IGN
Jumpered OPTOOUT to TSEL
Jumpered IGBTin to JS10(ign)
Jumpered TACHSELECT to OPTOin
Jumpered XG1 to XG2
Pullup resistor (1k ohm 1/2 - Brown, blue, red and gold) between S12 to the middle of the IGBTout and IGN
Hopefully this is right?
MS2 V3
jsmcortina
- MegaSquirt Guru
If you are trying to use the pullup resistor to help with the hall sensor then that is the wrong place. You have added a pullup resistor on the coil output.Housey wrote:
Jumpered XG1 to XG2
Try putting a 1k resistor between TACHSELECT and S12, leaving the TACHSELECT-OPTOIN jumper as it is.
James
