Page 1 of 2
Flow rate testing, How?
Posted: Wed Aug 09, 2006 8:34 am
by Avinitlarge
How can I check the flow rate of some injectors I have??
Posted: Wed Aug 09, 2006 10:09 am
by Ferret
Basically it involves attaching the enjectors to a fuel rail, FPR and pump, just like in a car, turning everthing on with the injectors pointing into a cups/bottles or any other suitable containers and measuring the amount of fluid collected over set period of time.
Avner.
Posted: Wed Aug 09, 2006 1:28 pm
by Avinitlarge
Ferret wrote:Basically it involves attaching the enjectors to a fuel rail, FPR and pump, just like in a car, turning everthing on with the injectors pointing into a cups/bottles or any other suitable containers and measuring the amount of fluid collected over set period of time.
Avner.
any Idea what the set period of time could be?? I belive the injectors could be 440cc but im not 100% sure, I would like to test them just to make sure
Posted: Wed Aug 09, 2006 1:39 pm
by Ferret
440cc means 440ccs of fluid per minute (usualy measured at 3 bar of pressure), but you can run the test for let's say 30 seconds and multiple the amount of fluid by 2 to conver to cc/minute.
Posted: Wed Aug 09, 2006 1:47 pm
by Avinitlarge
Ferret wrote:440cc means 440ccs of fluid per minute (usualy measured at 3 bar of pressure), but you can run the test for let's say 30 seconds and multiple the amount of fluid by 2 to conver to cc/minute.
I thought thats what it was, Just wanted to make sure
Posted: Sun Aug 13, 2006 4:44 am
by Avinitlarge
Ferret wrote: 440cc means 440ccs of fluid per minute (usualy measured at 3 bar of pressure), but you can run the test for let's say 30 seconds and multiple the amount of fluid by 2 to conver to cc/minute. I thought thats what it was, Just wanted to make sure Thanks
Megasquirt V2.2 main board MegaTune 2.25b717 Extra024s13
WWW.MONDEOTURBO.COM
-------------------- m2f -------------------- This post is at:
http://www.msefi.com/viewtopic.php?p=135508#135508 -------------------- m2f --------------------
Posted by email.
Posted: Sun Aug 13, 2006 5:40 am
by Mk1rocco
Avner.
I've got a follow up question. What's the longest amount of time you can run an injector at 100% without damaging it? Or, is it neccessary to hook it to some circuitry which mimics the ecu providing a pulse train with fixed duty cycle preferably less then 85%?
Posted: Sun Aug 13, 2006 6:04 am
by Ferret
http://www.msefi.com/viewtopic.php?p=135502#135502 -------------------- m2f --------------------
Posted by email.
Posted: Sun Aug 13, 2006 6:12 am
by Avinitlarge
WWW.MONDEOTURBO.COM
Posted by email.
Posted: Sun Aug 13, 2006 6:55 am
by woh
