TPSAcc - what is it and what values should I have????
Posted: Mon May 29, 2006 6:50 am
I am running MSnsS+Extra 029q with EDIS on a Toyota 4AGE with GSXR 750 ITBs.
I have got the VE table sorted but I am having trouble with AE with either MAPdot or TPSdot it stumbles before picking up. I have using megaLogViewer to see what is happening.
At a constant throttle TPSacc = 100 but when I add throttle to TP value increase but TPSacc jumps wildly to a - value then throws up a massive + value, yet when a take my foot off the throttle it stays at 100 - is this correct and what effect does it have on AE?
I don't get a very stable MAP signal at idle if flicks about from 57 - 63 ish can anyone recommend either MAPdot ot TPSdot for AE and some values to use as start points.
The TPS values seem OK it's the TPSacc that jumps arround and they don't seem to match eg:
If I stand on the throttle TP goes form 0 to 98 and stays there TPSacc goes from 100 to -12, -17, 187, 158.
I have attached a sample log
Thanks again
Neil
Thanks again
Neil
