Measure injector flow with ms2
I'm starting to msns a opel/vauxhall corsa gsi, but i've already buyied the ms2 chip (for the ms2-extra version that james is working on).
Befor install the ms-ecu in my car, i need to measure the flow of my injectors (i wasn't able to find any info!!!).
Is this possible with the ms2 chip? How accurate is?
Thanks!
In the release of the V2.6x code, Bruce said,
and,Bruce wrote:MS-II (has a) mode which can be used as an injector flow bench. We get several inquiries a week on the JectorRate FI driver setup, enough that we think that adding this mode will be useful. The plan is to set up a specific injector pulse width, duty cycle, and an adjustable commanded number of pulses. So, an injector an be plumbed up on a test stand with test fluid, and the injector exercised for a specific number of pulses/widths. And the injector open time and PWM current limit will still be there, so these can be characterized in the flow. The test fluid volume can be measured, alternatively the mass change introduced by the fluid can be measured on a sensitive scale. If people really like this mode, then we can also fire up one of the ADC inputs and allow one to add an accelerometer input. What you can do is take one of the low-G accelerometers available from Freescale, ST, or ADI, physically clamp it to the injector, and rapidly sample the analog voltage. The accelerometer will pick up the motion of the injector pintle, and the open and close positions (the point where the pintle slams onto a stop) will really show up on the time-sampled spectrum. So injector open and close times can be directly measured - pretty cool indeed!
I will attach a rough INI file that exposes the test mode.there is a fuel injector test mode which allows you to set up n squirts of any input PW and off time. It then sits there waiting for either a reset command from MT or change the test option and reset to resume normal mode. This could be used on the bench for commercially testing/cleaning injectors or to clean/test them in your car by pulling out the injectors from their pockets and letting them squirt into a can. The cost of a complete MS-II fully assembled is still way cheaper than a commercial tester/cleaner. (Bruce and Al saw one for $8000 and all it had besides a controller were 8 burettes.)
I'm reading this message and this is what I want!!
I was thinking about a way to measure the opening time of my injectors and i saw the jectorrate FI but now I know that the 2.6x code can do this!
I don't understand what you have written: So, I have to download the 2.6x code (which?) and then select the INI file you have attached in megaconfigurator and that is all? In this case, does this mode need the RPM or others informations to feed the injectors or is there a a specific menu in MT?
For the opening time, if I buy an accelerometer(without using the 2.6 code), all I have to do is to fix it to the injector and measure with a scope the voltage while the injector is opening?
Did you ever do this?
I know that there are a lot of questions, thanks for your reply
Note: where can I find the software and files for the jectorrate Fi?
Ludovic
Engine: 1300 cc hyundai (G4EH), 4 cylinders, port injection.
If I build the jectorate by myself, i think that there is a software for this, Am I wrong??
Whith this way, I'll know the opening time of my injector but during this opening time, the fuel is flowing until the injector is fully opened.The most accurate would be to build the accelerometer circuit, and display the accel output on a 2 channel scope triggered by the injector line from MS2
So, Is there a way to compute or measure the flow during the opening and open time?? i'm curious.
A student of my school fed an injector (high impedance) during 30 seconds to measure his flowrate without any damage but I think that it's huge!!I just don't have a feel for how long you can hold one open without damaging it or the inj driver
Ludovic
Mike_Robert
-Mike
I have heard the same thing, but I have also read papers where they model it as an average of 2/3 full flow during opening and 1/3 full flow when closing. I have derived this based on the equation for charging/ discharging a coil plus factor in the spring. Both can be correct statements if you consider 2/3 flow for a couple of us to be negligible - which I do. But still, the spring is what makes me think its not quite just a few microsecs. Would certainly be an interesting measurement.
I have been measured opening times from a REALLY big injectors (from a diesel engines with several thousand kilowatts). In those injectors it is possible to see a change in current when it has been fully opened. I don't know if it possible in these small injectors - I have to try...Ludotech wrote: For the opening time, if I buy an accelerometer(without using the 2.6 code), all I have to do is to fix it to the injector and measure with a scope the voltage while the injector is opening?
Injector current will suddenly sink and then continue to increase. So there is a small valley in current when it has been fully opened.
Mike_Robert
teg, yes, I can clearly see that behavior with the limited number of small, Japanese/Bosch style injectors I've bench experimented with. The current dip does appear to correlate well with real life experimentation on a running install.
-Mike
Are you sure? I'm pretty sure that many automotive (or ECU) manufacturers uses this current dip to detect valve (or injector) opening in realtime. Are you sure that this doesn't correlate real life? This current dip occurs when magnetic core stops moving...Mike_Robert wrote:The current dip does appear to correlate well with real life experimentation on a running install.
Of course when using electro-hydraulic injectors, it doesn't correlate real life.
