Warmup Wizzard and 71°C value. Lean situations...
Posted: Tue May 23, 2006 12:22 am
Hi Mates,
I have some curious problem with my engine running with MS.
I have a Ford Fiesta 16V with a 1.8l Zetec 16V engine and throttleboddies mounted.
Everthing works fine except two things:
1. The engine is tuned very carefully. I tried to tune a VE table which is just a bit richer then needed. So I have no lean situation while driving and no humbling when I try to start from a lamp or something like that while GEGO saves the fuel while normal driving.
But during warmup I have one specific temperature range that is alway lean: 71°C. Within warmup wizzard I'm not able to change that value, but I need to. It is allways set to 100% but the Zetec engine still needs more enrichment until it reaches the 80°C mark.
So, how can I change that value? If I try its always set back to 100% but I would need 110% around 71°C... it would be cool to get it back to 100% at 80°C.
2. My engine always runs lean when it rains. I can do everthing with the car when the weather is fine, but if it rains the whole VE table is too lean.
Can I create some special configuration for wet weather or do I have to create a second VE table for these situations?
Thanks for your help! I hope anyone can understand what I tried to explain
Greets Timo
Greets Timo
