Flex Fuel doubt
Ricardo_Penteado
Flex Fuel doubt
Is it really necessary? As we use alcohol a lot, nowadays, here in Brazil something between 80% of the 0km cars are Flex Fuel originally (I myself have one), and they really don´t have any special sensor; all the "magic" is made only by the EGO sensor (a narrow band one).
Assembling (again) MSII V3.0
jakobsladderz
There are no hard-and-fast rules, if you can think of a way to do something with one less sensor (take ion knock sensing vs seperate knock sensor) and make it work, all the better. From a coding/logical simplicity point of view, using a flex fuel sensor allows the same VE map to be used and just changing the inj cal in relation to the fuel blend (note, this doesn't take ignition into account). The O2 approach may take a little longer to stabilise and require a bit more 'guesswork' on behalf of the control system, but may otherwise work just as well.
