How about this for a surge tank?
Posted: Tue May 09, 2006 11:26 am
by BottleFed70
Check these out:
http://www.parker.com/RACOR/PRODUCTTABL ... UMFLOW.JPG
They are designed around diesel engines, but some will also work for gasoline. Looks like it would be a great filter/tank combination with it's own vent to "burp" air.
Posted: Tue May 09, 2006 2:38 pm
by Deaninkc
I got a setup from BC Bronco's that works well. I probably could have duplicated it and saved 20 bucks. They use a regular remote oil filter mount and Wix gas filter drill and tap the top for a return and add a piece of aluminum tubing to the center output so that it reached the bottom.
They include all the fittings and some rubber hose.
Posted: Sun May 14, 2006 10:18 pm
by !!!ALEXANDER
I have an older Diesel water seperator, (the square one) off a GM (GM or a Detroit? It's been a while, so I forget) truck.
The mounting face has two "O" rings on the surface and the whole filter/seperator thing is clear, and the thing it mounts to is vary user/installer friendly.
