Does a narrowband switchpoint matter?
I am getting these certain lean "spikes" at certain points after using autotune. I was checking the logs and most of the time the voltage is over 0.800, but to be certain, wanted to ask here.
Which is better, 0.5XX or 0.784? (According to logs, there is a very rapid and straight drop from 0.9 to 0)
Thanks.
78Spit1500Fed
- Site Admin
With that in mind, it would reason that any switchpoint between your minimum and maximum voltages would be suitable for making that lean/rich determination; the .5v threshold is halfway between min and max, and according to most OEM specifications, is the point where stochiometric can most reliably be expected.
Moving that switchpoint by a couple of tenths (say to .4 or .6) would not adversely affect the performance of your motor... but the closer you get to the minimum and maximum values, the less likely you're actually indicating a stochiometric mixture to MegaSquirt.
My advice; leave it alone. Find out why there are lean spikes and solve that problem first. Dive into the log and find what MAP and RPM bins would affect your spikes and enrich them. Also, take into consideration any accel/decel enrichments you may have activated.
-Brian
