I have the fuel pressure too low. It's only set at 32#'s when it should be at 42#'s. My Req Fuel and VE table are tuned for the wrong fuel pressure. Is there a calculation I can make to adjust everything at once so it will still run good? I tried to up the pressure to where it belongs and it just kept flooding even after lowering the req fuel. I got so frustrated I just loaded up an old program that I knew worked and went cruising around on auto tune.
G'day "Arrowhead"
I think if you open "VE Table" (where you set the VE constants) then select "Tools" then "VE Specific" you should see "Reset ReqFuel", this should do what you need, check this out for more info => http://www.megasquirt.info/megatune.htm#a1tvr
