Escort GT Turbo
Posted: Mon Apr 24, 2006 6:41 pm
Ok I have a MSII V3 board and im running 2.3XX
Vehicle is a 93 escort 1.8l turbo. 360cc injectors. (est 200hp and 175tq?)
anyways my prob is the car is very tough to get started. i would say usually it takes around 7 tries to get it to start...i have tried to adjust the ve table thinking its running to lean but im at a loss...if someone who knows more then me could just simply look over this msq and please tell me if i missed something obvious i would appreciate that...keep in mind that once its running its running good...just getting it running is obviously the problem...thanks all in advance.
Seriously, pre-ignition or detonation knock (if that's what it is) can be caused by many things including AFR, spark plug heat range, charge temperature, charge atomization, chamber temp, turbulence, 'squish' area, fuel grade, piston-to-head clearance, ignition timing, cam timing, crossfiring, hotspots, etc.
