duty cycle problems
Posted: Sun Apr 23, 2006 8:41 am
Im sure Ive seen threads on this before but cant find them
. Someone can probably answer this quick enough anyway.
Is it normal for duty cycle in datalogs to be > 100% (if injectors are too small). I spent the day retuning for a new injector/cam combo and reviewing the logs the duty cycle is up to 128%.
Not sure if this is normal (eg - 128 is what would be required which doesnt seem likely considering the cam/injectors) or if I've stuffed a setting up somewhere.
Mark.
Mark.
