water injection
Posted: Tue Mar 21, 2006 8:48 pm
by davidvwm
can i use a fuel injector for a water injection will it rust out on the inside :RTFM:
Posted: Thu Mar 23, 2006 6:15 pm
by elturbonitroso
i think you cant will rust
Posted: Thu Mar 23, 2006 10:48 pm
by PSIG
Actually, I'm getting ready to test this question myself. I have early and late Bosch, ND, Keihin and Rochester injectors to test with and was waiting to get a few more (Mopar, Lucas, & ?) at the 'yard. My test will be empirical, but will include cleaning, open flow test and filling with 50/50 alky/water mix.
I figure checking them after 1 day, 3 days and then a week will give quick results, then every week thereafter for a couple months. I will do the same with a couple common EFI fuel pumps.
If anyone has suggestions for the test please speak up. If there are any additional items to test you can throw them at me or wait for a detailed outline so you can repeat the same conditions.
David
Posted: Mon Mar 27, 2006 12:54 am
by Paul Smith
It's all been done before. The only way you can use a fuel injector for water injection is to mix water soluble oil with your water.
Posted: Thu Mar 30, 2006 8:40 pm
by davidvwm
Paul Smith wrote:It's all been done before. The only way you can use a fuel injector for water injection is to mix water soluble oil with your water.
how much do you mix in and wich oil do i use
Posted: Fri Mar 31, 2006 8:06 am
by PSIG
I would also like to know. I get answers from "all the Bosch adn Keihin guts are stainless and won't corrode" to your answer of the opposite and to use oil.
I certainly don't want to trash injectors and pumps in testing but need something difinitive to post for future use. It is a common question and the answers aren't so common.. :? Any info you have would be most appreciated!
Posted: Fri Mar 31, 2006 11:56 am
by davidvwm
so can i just splice in a injector from the main (4) inj and use the one inj for the water inj
