alpha-N tuning
Posted: Wed Feb 22, 2006 9:58 pm
Hi guys! Has anybody been tuning an overcammed monster lately? The baseline: 406 inch Chev smallblock with a 280 @.050, .650 lift, 108 lobe center cam. Guesstimate 700 flywheel hp @ 7000rpm, 8k redline, 2-4 inches of vacuum @ idle (700-1000rpm, wouldn't idle below 2k on carb), 5000 stall converter, 13-1 compression, 110 octane leaded race fuel (hard on O2 sensors, using 5 gas for feedback). It's in an 88 Vette for a customer of a friend of mine, he built the engine (about $18k). Current file is: Req'd fuel: 406 inch, 52 lb/hr injectorsx8, 14-1 A/F = 10.8 u sec, here's the goofy part: VE table @90kpa on alpha N:
kpa 80 70 55 45 35 60 75 80
rpm 1000 1500 2500 3600 4700 5800 6900 8000
We had to go way rich to start it because of the high overlap cam (blows half the fuel out the tailpipe near idle), then gradually reduced it to get it to rev up. It doesn't get "on the cam" until about 5000 rpm, really wants less fuel below that except near idle. This is all without load. We plan on doing a dyno session before taking it to a test and tune at the dragstrip. Is there a way I'm not seeing to tune the VE table while the engine is running? We're using Megatune, the board is Megasquirt I v2.2, no ignition control. I sure wish I could have started out with a mild 350 for the first Megasquirt experience but nooooo, that would have been too easy...
Thanks!
Thanks!
