Are loud injectors an issue
bleoh
Post by bleoh »
Compared to OEM systmes my injectors are very loud. The make a clicking noise when running. Should I look for a setting in MegaTune that might be off or is it nothing to worry about? Thanks. Brian
MS2 v3.0 MT2.25 controlling 6 high z injectors and ignition
Big Creek
Post by Big Creek »
I would assume you have your PWM set correctly. If so you probably have nothing to worry about. Some injectors make more noise than others.
I have had three setups on my car. First 4 low-Z with PWM = Very quiet then same injectors with resistors and no PWM = Very loud! Then I went to high-Z injectors and they fall in the middle. Not real loud but not quiet either.
Todd
fscott
Post by fscott »
I was told once that if they're not clicking, they're not working.
New injectors are pretty quiet, but before long, they click. If old injectors don't click, they may be gummed up and need cleaning.
bleoh
Post by bleoh »
Thanks. I think I have my PWM set up correctly (looks fairly straight forward for high z injectors). I did have my injectors tested and cleaned by one of those services, so I think they are good. I won't worry about it.
Brian.
jonfx4com
Post by jonfx4com »
my weber marelli injectors are loud, so loud I spent an hour adjusting the valve clearances before I realised it was not the problem! I found that going from 1 squirt to 4 squirts helped a lot, became a buzz not clicks if yoe see what I mean.
Jon
bleoh
Post by bleoh »
I know what you mean. I checked my oil thinking it was low.
hudsonhawk
Post by hudsonhawk »
I am running 2 Holley low-z injectors in a GM TBI. They click audibly and have since new.
'72 CJ-5 w/'83 AMC 258 running a late 80's GM TBI controlled by MegaSquirt.
HVviceP
Post by HVviceP »
Just be sure it is in fact the injectors that are loud. Use the screwdriver to ear trick or get the cheap automotive stethoscope, it works really well.
My buddy installed a new set of disc injectors and a batch fire EFI in his car at the same time. It sounded like a diesel but he wrote it off as the mammoth injectors all letting go at once and was proud of it. Turned out 70 miles later that it was the valves bouncing off of his pistons (had also just put in a new oil pump so he had a lil more lift, at least thats all we can come up with) End of a valve/head/piston/rod/block while cruising at 1700rpm...
Phil Calvin
1990 Mustang GT
MSnS-extra
More Details
jonfx4com
Post by jonfx4com »
This has me thinking. I listened to a DOHC ford engine today runs the same injectors I have and they dont click, at least not close to the same loudness. Is it possible that OEMs are ramping the open signal to prevent it. Seems unlikely I know, just thinking out loud. I cant ever recall hearing an OE engine making the same noise.
Jon
